The VAF News - 2.16.2026. #6495.
DeltaRomeo
doug reeves: unfluencer
Staff member
ForeFlight v18.1.1
ForeFlight 18.1 was released in February 2026.
https://www.foreflight.com/releases/18-1
Mine is on the engine side of the firewall on my RV6 - carbed O-360 (see pic). The “downspout” is from home depot. If it looks crooked it’s because it is. The threads on the brass tube are cut that way. I’ve tried two of them and they are both the same. A standard fuel tank drain is on the bottom using a coupler. Nothing leaks - works fine - drain sample through a hole in the cowl below it. I have to turn on my electric fuel pump to get more than a few drops out of it. Easily opened up for checking/cleaning during my CI. Ive never found anything in it.
OFF TOPIC:
Past ‘VAF News’ issues:
