The VAF News - 12.23.2024. #6240.
DeltaRomeo
doug reeves: unfluencer
Staff member
dr
johntwilcox
etocr
jaybob
mfleming
Milestone: First Engine Start
…cgeyman
Nashpdman
Technique …Nihon_Ni
Riveting bottom skins solo.
Here's how I did my RV8 wings solo. I was in the basement, so I clecoed a piece of scrap to the then, and used it to tied the skin to a rafter and adjusted it after each series of riveting in an L-pattern others have described above.
VS Help
…YME 12
glenadavis
Replaced brake pads - at correct torque it binds
I replaced my brake pads on my 6a. I fully returned the master cylinder all of the way. However, when I torqued the caliper bolts down all the way, the brakes grab the disk and do not spin. My mechanic told me this is common, and the solution is to slightly back off torque so it can spin.
Has anyone experienced this? Are there spacers I can get to make the caliper slightly wider and not grab the disk?
OFF TOPIC:
