Twenty. Nice round number. Saturday the 21st will be the 20th anniversary of the first forum username created here on VAF that wasn’t me. ‘Scorch’….my friend Ross (washed up has been ….his words). I called him saying I was trying out something called ‘forum software’ and I wanted to see if he could ‘sign up’. I was still three years away from taking the terrifying leap and doing it full-time (still terrified). Before that for me it was some Yahoo mailing lists, and before that a simple message board that I assume is still online somewhere offering Viagra to the masses via spambot.
Anyone here from day one reading this? Some I can think of off the top of my head....
And here we are two decades in, discussing RV stuff still, shooting for 20 more years Good Lord willing. A great community for sure! Thank you for helping make it what it is, and thanks to Bill K. for helping keep the infrastructure modern.
Wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
Build Update …RossK
Right tank done.
brian tucker
Q/A Canopy Latch Detent
Q: Is there supposed to be a detent for the canopy latch handle? My latch handle closes fine but will move off the micro switch in flight. I am thinking about remaking the nylon sandwich piece with a slight dent for the handle to sit in at the stop. I’m wondering if there is a better way besides creating friction on the handle shaft.
A: There is a pin on the back of the handle that slips into a notch at the back of the latch block.
https://vansairforce.net/threads/canopy-latch-“detent”.231782/post-1811757
briantucker
LettersFromFlyoverCountry
OFF TOPIC:
- Jaybird
- Mel
- Danny King
- Sam Buchanan
- Don Hull
- Paul Dye
- Lot of friends....
v/r,dr
Build Update …RossK
Right tank done.
RV-7A #73840
Well, I've started building an RV-7A I'm the third owner of this Kit and if you haven't read Vans warnings about buying older kits, particulary the bit about unboxed, original packaging you should. When I unboxed the kit for the first time in its 14 year life, this is the result of storing...
vansairforce.net
brian tucker
What happens when your pants explode?
On the takeoff roll from VNY last week I felt a substantial “thud” from the right main just before Vr. It felt like I had hit a pothole, but the remaining few feet of my departure continued without issue so I pulled back and lifted off. Landing at SMO, I touched down the mains on what felt like...
vansairforce.net
briantucker
Flat spot on tire
We had a little incident on landing (will post in another thread) that resulted in our right main skidding for maybe 50ft. As a result we have a flat spot and I’m not sure whether it is safe to fly on. What do you all think and how do you determine whether a tire with a flat spot is safe to fly on?
vansairforce.net
Another Rotax SB: Expansion tank
ROTAX is trying to set a record for most number of service bulletins in a week, I guess. Here's another one: https://legacy.rotaxowner.com/si_tb_info/serviceb/SB-912-080UL_914-060UL_912i-015iS_915i-015iS_916i-005iS.pdf That one provides the S/N of experimental engines (fortunately, I escape...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
