The VAF News - 12.12.2025. #6456. Chocked full of RV goodness (and extra chunks of news)!
DeltaRomeo
doug reeves: unfluencer
Staff member
Wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
First flight took place this morning!
Hi Larry, I decided to go with this approach but as soon as I looked at the rear of the hole again, I realized the empty hole above goes through a tab so a double would not sit flat. I went on to extract the additional neighbor rivet and made one doubler for 3 holes and one for two, shown clecoed in the attached pictures. I matched the material thickness of the ribs which was 0.025". Thoughts?
Works fine mounted like this. There was a post 4 or 5 months ago that said he positioned his under the overhead console and it worked! I did not attempt this as I thought would have zero chance. 6 ft of 16 awg into my main bus that operates at 14.0 volts, no issues.
I’ve had another busy week tinkering with the Rocket.
Definitely some inconsistencies here between Chapter 43 and Chapter 49. Chapter 43 shows your circled location, while 49 shows where you actually installed it. I suspect Chapter 43 shows the non-EXP version. I'm not sure about Chapter 49.
OFF TOPIC:
Past ‘VAF News’ issues:
