Spent the weekend working the two part time jobs, so no RVing, but the plan is to get out to 52F at least one day this week to scratch that particular itch. It keeps me right side up LOL.
I hope you had a nice weekend and got to spend some time with your RV or RV project.
Have a great Monday.
v/r,dr
What did you do with your RV this weekend?
XXII. On Aesthetics: Canto VII
“You should be able to back the screw out by using an awl or small prick punch and very lightly tapping the outer edge of the screw in a counter-clockwise direction, provided it wasn't cross threaded or installed with loctite.”
OFF TOPIC:
v/r,dr
WDYDWYRTW? 11/1-2/2025
What are you doing with your RV this weekend? Getting this weekend‘s thread started, and I hope you’re having a great one. v/r,dr
vansairforce.net
Fullerton Aviation Painting @ 3DW Springfield Missouri
Has anyone had any experience with Fullerton Aviation painting service? Do you know of an aviation paint scheme designer that you would recommend?. Thank you, Bill
vansairforce.net
Lower main gear intersection fairing question
I have just finished 48-11 Step 1 where I added some layers of fiberglass on top of the lower gear leg intersection fairing. I'm not happy at all with the trailing edge once it has cured and I have it cleco'd in place (see attached photos). In one photo I clamped the trailing edge just to see...
vansairforce.net
Meditations on a Grounded RV
I. Teardown What does it mean to savor the fast, fleeting, and final hours on the tach before the engine goes idle and the last puffs of burnt fuel begin to fizzle into a wide and far-reaching silence? What sense does one have of eternity when, with a single glimpse, there is captured high...
vansairforce.net
Upcoming FL events?
Hi all, I've been out of the loop on this stuff for quite a while. It seems like this time of year was always happening with a variety of events, some on the same weekend. I know that Love Landing is hosting their event this Saturday. Do ya'll know of anything else planned? Seems like the Flying...
vansairforce.net
Denso Alternator dropping offline
Yes - it was a PP alternator, the cavity in the SRE was worn, and the bearing had "spun". Root cause was unknown, but speculated to be heat related. There is/was nothing visibly different in the SRE/bearing assembly or parts between the PlanePower and Genuine ND, WAI/Transpo, B&C or other...
vansairforce.net
I (didn't) give up
I put the CPS wires and knock wire back in the connectors and tied them with zip ties then put the fuel system and injectors back with new O-rings and lithium grease. I had a bit of a time with the pilot side heat shield and getting the shield between the fuel pressure regulator and case, and...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
