N731VF Became a Plane
My RV-10 passed inspection and became a real plane today. Took 3 years 11 months and 6 days from first rivet to passing inspection. First flight still to happen but now It can (once I put everything back together).
vansairforce.net
Fuel Line Routing
Titan IO-340 with Airflow Performance FM-150 servo and crossover exhaust. What's a typical route to take for the fuel line going up to the spider? Where it exits between the cylinders takes it into the tight space between the sump and the exhaust. Based on the length of the fuel line provided...
vansairforce.net
Fuel Tank…Again
Successfully repaired my LH tank. Thanks to everyone for the guidance. Especially the EAA member who guided me locally. But now since I have had the tanks full for over a week, the RH tank has started to leak. This one is undoubtedly easier (KNOCK ON WOOD), since it’s coming from one of the...
vansairforce.net
Nose gear pants repair...Tug Guards
I had to repair my nose gear wheel pants (again) and took the opportunity to rebuild them a little to accommodate a set of Tug Guards. My nose gear strut was loose in it's engine mount socket which put the axle where tow bars attach off-level by about a centimeter. Wasn't an issue with the...
vansairforce.net
WAYDWYRTW? What are you doing with your RV this weekend?
... 1:25 PM central standard time Sunday. Changed the title this weekend to get your attention LOL. ;^)
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
