Back from Cape May NJ with Daughter
vansairforce.net
Airworthiness Certificate 10/23
Out of Phase 1 Oct 23, 2024
N677AT
Superior XP O-320, 160H
WAYDWYRTW? What are you doing with your RV this weekend?
... 1:25 PM central standard time Sunday. Changed the title this weekend to get your attention LOL. ;^)
vansairforce.net
Aileron rod end bearing attachment
Adjusted the control stick/pushrod/bellcrank/aileron push rod to aileron settings. Can’t find the drawing for the aileron push rod/end bearing to aileron attaching hardware for the 6 (need to know what AN3 bolt length, washers and order/sequence. Drawing reference number and location on the...
vansairforce.net
Show us the status of your 9/9A project!
Panel wiring is 95% complete, so the canopy goes back on! Next up, the rear window, then back to fighting with the cowl fit. I may or may not have shut the canopy, turned on the avionics and made plane noises.
vansairforce.net
Multiple ground wires to a single location?
I have two grounding blocks (forest of tabs) just behind the instrument panel. Total of 40 tabs available. I also have many, many leads needing grounding. While I believe I have more tabs than leads needing to be grounded, it also seems like I could piggyback several leads onto a single tab to...
vansairforce.net
Electroluminescent panels for avionics
I'm down the rabbit hole of avionics panel lighting. I'm considering Electroluminescent panels. Anyone worked with these before? My concern is the reliability of it long term and the DC/AC inverter required to run it. Thoughts?
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
