The VAF News - 11.21.2024. #6219. Starship Launch from RV!, RV-10 comes to life, more…
DeltaRomeo
doug reeves: unfluencer
Staff member
You’re gonna just have to click on this…
Weefle
Spotlight on Classified
…RV-8 Project F/S. James Riordan of Kanab, UT.
Retired Firefighter.
Jetmart RE Rotisserie
I used the rotisserie for a few things but found it hard to reach into accomplish a lot of tasks. I did keep the fuselage on the floor as long as possible. Did all wiring, canopy, and interior paint with it in this position. It was an easy step in. I did not put it on the gear until it came time to mount the engine then used a strap and engine hoist to lift it.
AlphaCharlieBravo
TS Flightlines Update
We have made another production run of the Bendix/Avstar version of our flow transducer bracket. Currently in route to the anodizer. Yes a LONG time coming, and we DO apologize for the extended wait. No excuses, but this old man trying to learn CAD, and then going through our steps to make sure things are correct. (Steve takes the file and 3D prints a model, sends it to me and I test fit it.) Several very minor changes.
After getting this mocked up, it occurred to me that we can make another subtle change and make this unit compatible for both the Bendix/Avstar flow dividers on the Lycoming 75009 steel mounting bracket, AND the AFP flow divider on its mounting bracket. So---on the next run, that change will probably be made. Included hardware is the same, fittings for the supply side for BOTH versions included. We've decided to sell the hose separately, because not everyone uses the same servos, and installs it the same way. ( You builders with Superior Sumps know the issue). So the hose will now be separate so we can customize it for your install. Yes--we do have most of the normal configurations (11 just for IO320/360 flow divider located transducer), so you see why we are going to make this separate.
Zero4Zulu
…perforating main jet to equalize fuel distribution
OFF TOPIC:
