The Baffling Paradox……
While that sounds like a clever word play of a title, it is literally a truism - let me explain! We all know that good engine cooling (generally determined by good control of Cylinder head Temps) is dependent on a baffle system that develops nice high pressure above the engine and that forces...
vansairforce.net
WDYDWYRTW? Oct 4-5, 2025.
....getting this week's 'What did you do...' thread started. v/r,dr 12:15 CDT Saturday
vansairforce.net
What tool do you use to dimple extra tight tolerance on inboard aft most #8 nut plate on wing rib
Working on page 20-5 dimpling for the k1100-08 nut plate that will go on the bottom aft and inboard most location of the wing. I've got a rivet tail in the way from lining up the female die to the hole center and the male die would be fine except the squeezer interferes with the flap hinge...
vansairforce.net
Slider canopy variance build ?
My slider has a noticeable difference in the weldment of the sides. (Approx 3/16) The right side is parallel to deck, left has a slope. Should I grind off the L "post" holding the slider bearing to same as R? In my case 1 7/16"
vansairforce.net
Wonky RPM indication
As I have mentioned in other threads, the engine in my RV-10 was overhauled and (re)installed a few weeks ago which resulted in a few issues for which this group has been extremely helpful. Ever since the plane started flying again after the engine install (last 4 weeks or so), I had noticed...
vansairforce.net
Modifications that you have Made to your RV-12 after Certification? E-LSA Only!
Thanks! I knew the reason was that they though it should emulate a manual flap handle. But that's bunk! Every pilot I've flown with in the -12 repeatedly moves the switch the wrong way. When you see a switch, you don't think "flap handle". That just doesn't jibe. If I could, I'd either...
vansairforce.net
12iS B.U.D.S. Connection Issue
Note, this is an iS issue…. I’m trying to resolve why when I connect my Level 2 BUDS dongle to the data port, the software will not recognize the ECU. I first tried to download a friend’s data logs from his 12iS and BUDS couldn’t see the ECU. No recognition of the engine serial number and no...
vansairforce.net
Ball-park estimate for paint job?
For those that are thinking about doing their own paint work, I'd suggest hitting the local auto salvage and buying the cheapest metal fender and hood or trunk lid you can get and use it for practice. Do the prep work and paint it white and experiment. Then sand it all down or strip it and then...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
