Pls excuse early Thu push - side gig (icing recurrent sim) during prime typing time.
v/r,dr
romaja
cjs
charlesmc
New Rudder Lock for -14
(possible advertiser here shortly - talked on the phone with Chris yesterday. Thought I’d mention the product in advance. dr).
The DroMightâ„¢ Rudder Lock is the best rudder locking system for the Vans RV-14 and RV-14A aircrafts.
This revolutionary product prevents wind from causing unexpected movements of the rudder control
surface and can be secured from within your aircraft while parked on the ground. This tension bearing
dual rudder lock system allows for the rudder to have flexibility in heavy winds while also keeping it safe
and secured when parked on the ground. The DroMightâ„¢ Rudder Lock is quick to install, easy to remove,
light weight and effective. A version for the RV-10 is coming soon.
https://www.terrestrialimaging.com/products/dromight-rudder-lock?_pos=1&_sid=1aa3ee03a&_ss=r
OFF TOPIC:
v/r,dr
romaja
FF-01414 X-over cowl close out too short
It appears that part number FF-01414 X-over cowl close out is too short. As depicted by the arrow there is a gap? EXP-119 engine and cowl. What am I missing?
www.vansairforce.net
cjs
Whirlwind 300 series composite prop issue on my RV14
Want to bring to light an issue I am having with the 300 series three-bladed Whirlwind composite prop on my RV14: Scoring of the hub from the rubber gaskets. Bottom line, so far its a Cluster F and I am not sure how it will resolve. Background Info: RV14 with IO-390 Thunderbolt - about 620...
vansairforce.net
charlesmc
3D Printed Drill Bit Organizer
To speed access to common RV drill bits, I created a drill bit organizer in F3D and then 3D printed it. I've found it to be very useful, so I thought I'd post the design. The slots to the right are unlabeled for misc. drill bits, but if there is a common size that I missed, let me know and I'll...
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
