dr
Status Report: RossK
Wings coming together.
Leading edge and then RH tank next.
https://vansairforce.net/threads/rv-7a-73840.225526/post-1801081
Status Report: Rv-12David
One more big event this week. Cleco’d on the tailcone for the first time. I wanted to get the rudder cables attached to the rudder pedal assembly. There’s beginning to be a lot of stuff in and around the tunnel so good to get it done before access gets any harder.
It’s motivating to se the fuse in one piece but just clecos for now. I plan to separate things again when the avionics arrive. It’s very reassuring to know it fits!
Status Report: …nohoflyer
This took way longer than I thought it should. I added an inspection window I saw on another builders project.
Stuck Valve Input …DanH
Unless I missed it, so far, at 160 posts, no one with consistent long term 15W-50 Aeroshell use has reported a stuck valve.
Partial or full synthetic is the lube industry's standard response to high temperature coking, as synthetics exhibit greater resistance to thermal breakdown. 15W-50 Aeroshell is currently the only approved piston oil with a significant synthetic content.
Note the stem temperatures in this TRW illustration:
Fresh Off The Bench ….SteinAir (Advertiser)
We (SteinAir) built this panel for 410RV. I think it's still the most recent one in there!
https://vansairforce.net/threads/show-us-your-rv-10-panel.18921/post-1801197
ATC_RV8OR
jmpratt
https://vansairforce.net/threads/battery-to-firewall-ground.230670/
OFF TOPIC:
WDYDWYRTW? 10 / 26-27 / 2024
....getting this weekend thread started. Hope you have a wonderful one! v/r,dr
www.vansairforce.net
Irv’s RV-7A journey
I started my build when I lived in a real house in W Massachusetts. I had an actual walk out basement that I turned into my shop. Actually it was a great motivation to finally clean, purge, and organize it. I built my empenage down there in about 9 months. Hiccup. My wife and I decided to move...
vansairforce.net
Sticky valve on a Thunderbolt IO390
To those who have completed SI 1425A, did you have to drop the exhaust to help re-insert the valve, or were you able to work through the spark plug holes, with a pickup tool? Also, to those who have used a magnet to help guide the valve back in, will a 1/2" magnet work, or does it have to be...
vansairforce.net
ATC_RV8OR
Vans Engine Delivery Survey Email
Got an email today asking to fill out a survey. Yes do you want it sooner or no leave it as scheduled. Anyone else get this? From time to time, Lycoming's engine production schedule changes. Sometimes unplanned delays occur due to supply chain or other circumstances. At other times, Lycoming...
vansairforce.net
jmpratt
OFF TOPIC:
vansairforce.net
vansairforce.net
