dr
HFS
jerry98b
Humrnv
Webb
rv8ch
g zero
…water xfer on printer at home.
https://vansairforce.net/threads/instrument-panel-paint-and-labels.230481/post-1799660
jcbarker
…how I handled those pesky rivets in the W-1011-L-14MOD.
Ben Ellis
plehrke
… spaghetti
https://vansairforce.net/threads/500-airports.202660/post-1799706
OFF TOPIC:
WDYDWYRTW? (Oct 19-20, 2024)
...getting this weekend's thread started. Hope you're having a great weekend! v/r,dr
vansairforce.net
HFS
EZ-OUT (el Brutus Jr.)
A while back, there was a posting about the difficulties in removing "cammed out" Phillips head (or other "cross hatched" configuration) screws where there is an adjacent (
www.vansairforce.net
jerry98b
Needing Some Encouragement
I'm sure all builders have felt the way I feel currently and I'm needing some encouragement. I am ready to start and finish my canopy, but looking at my engine and firewall forward has me feeling overwhelmed. I know it will all be worth it, but sitting at over 1,800 hours feeling like I have...
Humrnv
How to fix
What do think is the best way to fix this. It doesn’t actually looked crack rather delaminated if that’s the correct way to describe it? Someone opened my canopy and pulled up on it RV-6 Ft Worth, TX
Webb
Today was a good day
The RV grin is starting to grow on my face. Moved to the airport and attached to wings after it arrived. My A&P that is doing the condition inspection on my Bonanza came down and lended a hand. He brought some super slippery lube and the spar bolts seated with encouragement from a mallet. The...
vansairforce.net
rv8ch
EGT spikes on one cylinder
I'm about 90% sure that this is a sensor issue, but is there any other reason for an EGT spike like this?
vansairforce.net
g zero
jcbarker
SL-00092 and SL-00100
Hello all, Picked up the kits for the SL-00092 and SL-00100 on July 19, 2024. I was told I was the first one. I started on the 100 first as that is what's in the shop right now. My completed QB wings are in storage. I started working on it in earnest 7/27. The labor required estimate stated in...
vansairforce.net
Ben Ellis
Engine storage
I just received my IO-390-EXP119. The box has a yellow notice indicating that the engine is preserved to withstand 24 months under favorable conditions after leaving the plant and that I should not open the envelope around the engine until ready for use. The engine box is sitting off the ground...
vansairforce.net
plehrke
… spaghetti
OFF TOPIC:
vansairforce.net
vansairforce.net
