Construction Porn
….for your enjoyment.
akmeesan
hgerhardt
Another use for the jig
N11VC
OFF TOPIC:
Installing wheel fairings—a better way
While researching how to replace my old RV-6’s 1-piece wheel pants with today’s pressure-recovery units, I came up with a good idea: by assuming the wheel axles are aligned correctly to the airplane (they are), a jig could be built to hold the brackets in rig to install them to the fairing...
vansairforce.net
akmeesan
How to route throttle & mixture linkages with Superior cold air intake sump
Hello, I have an RV-7 with an IO-360, with Airflow Performance fuel injection. I have a 4-in-2 exhaust system (don't know which brand). I just upgraded from a stock horizontal intake sump to a Superior cold air intake sump. Turns out that: 1. the exhaust system appears to interfere with the...
vansairforce.net
hgerhardt
vansairforce.net
N11VC
Rear Tiedown
After the hurricane blasted through the north of this area I noticed that the rear Tie-down of my RV6A was bent and that the F-612 bulkhead was torn slightly. Winds were about 40-50 knots in this area. Something I'll have to fix unfortunately. The way the Tie-down was installed by the builder...
vansairforce.net
OFF TOPIC:
www.vansairforce.net
vansairforce.net
