The VAF News - 1.7.2025. #6248. Nice mix of construction questions, safety and motiviation.
DeltaRomeo
doug reeves: unfluencer
Staff member
danlh
dr
RE: HIC module RV12is
…Tony Kirk reply
Winterizing PIREP
David Paule 3B Update
Plugging along on the FAB. I managed to screw up the top plate and put another one on order, so I’ll get to redo many of the fitting checks that I’d just completed. What joy.
The glue decision has been resolved for that bottom Titanium plate I made. It’s being glued down with Pro-Seal.I had an unopened container in my freezer and figured this was a good time to introduce it to the room temperature world. After glueing down the titanium ellipse, I set it on a floor heat vent in the house, with weights to help hold it down. After a week it was fully cured. It might have been cured before then but that’s when I checked it.
The O-320 FAB plans call for AN970-4 washers for the mounting plate bolts to the carburetor. But these are so big that they overhang the air flow path. I got some AN970-3 washers, which are the right OD, and drilled out the ID for an F drill, clearance for the 1/4” bolts. Then I primed them (can’t leave a bare steel edge) and baked them. I bake small primed things at 150 F for an hour, and they fully cure. Just put them in a small oven on some aluminum foil. Don’t want food on my parts or primer on my food, after all.
kenandsteph14
lucaperazzolli
Ron_K
OFF TOPIC:
