The VAF News - 1.13.2026. #6474. Haemorhous mexicanus / Sialia sialis
DeltaRomeo
doug reeves: unfluencer
Staff member
Pro Tip Reminder:
If your post/reply has a molecule of politics in it, it sleeps with the fishes. Hundreds of thousands of sites exist for that kind of thing. Gratzi.
v/r,
d ‘Hitler to some’ r………….. ;^)
Nothing-too-fancy posting rules:
Finally pulled the trigger on mounting the Star Link antenna. It had been temporarily mounted rear baggage starboard side next to the AeroSport overhead. Worked well and picks attached above. Since I have the Showplanes composite tailcone was going to mount it there and the 10 could always use the added weight for CG enhancement but decided that access and mounting issues decided the wing tip was best. I used an already purchased frame mount and hardware and epoxied in place. (Click Bond adhesive and third-party studs) If I did not already have the hardware, I think Richard's idea using foam would be better. Also used Traash's step-up power converter that worked well.
Thanks for the mounting idea…but had a chuckle .. if you’re looking for your Torx bit, I found it
Yes -- LM317 is a 3-terminal adjustable linear regulator.
And, LM2575 can be used as a 5-terminal adjustable switching regulator along with an inductor and capacitor.
Seen out the VAF office window……dr
I could probable use this in the RV, actually. While going through the admin tasks of VAF, the morning birds showed up for a drink. Leaned the phone up against the glass and started tapping the watch.
The take: Male House Finch (Haemorhous mexicanus). Eastern Bluebird (Sialia sails).
OFF TOPIC:
Past ‘VAF News’ issues:
