Prop
Regarding post 350:
Many years ago I had the opportunity to have an in depth discussion with a pilot who had lost the prop of an S2B Pitts. The crank flange failed, the prop departed cleanly, no damage to cowl. The most important take from this discussion is that the pilot extended the downwind to allow for the increased glide. When he turned final he thought that he would land short. As he approached the runway his next thought was that he would overshoot a 4000 ft runway. He made it ok.
On the Pitts there is a huge difference between otherwise identical S1 aircraft, fixed pitch metal vs constant speed. With the fixed pitch 90 percent plus of my landings at home base were idle power abeam the numbers at 800 agl. I rarely had to add power. With the german constant speed, I could be at cruise speed on 1/4 mile final, pull the power to idle and land on the 1000' mark. Downwind abeam the numbers took 1000 to 1200' agl and a very tight pattern to make the runway.
I explain the prop situation by discussing the diameter of the prop in relationship to the wing area directly behind the prop. The larger the percentage of wing area affected by the prop, the more drag with the power at idle/flat pitch.
The fixed pitch wood props typically used on an RV tend to be smaller in diameter than "normal" and except for the RV9 tend to be very high pitch. Because of these two factors the props at idle or windmilling do not provide a substantial amount of drag.
Regarding post 350:
