I’m in the process of stripping a -7 now. I have all the flight controls off and stripped, the wings off and stripped. The fuselage is next. I am in process of taping up all the lightning holes. I will bag the engine, wheels, gear legs, rear window (tip-up), and cockpit.
I purchased 10 gallons of Sunset Strip from webberteck. Sunset Strip is a non-toxic, non-hazardous, hydrogen peroxide activated paint stripper designed for removing polyurethane, epoxy and other paint systems, and safe for fiberglass.
Lately I have been using Citri-strip from home depot. Half the cost of Sunset Strip and uses the same hydrogen peroxide. I won’t use it on fiberglass but it seems to be same-same. I used 7 gallons of Sunset Strip stripping the engine cowling and wheel pants and another 4 gallons of Citri-strip stripping the wings.
I have been spraying it on with a $40 harbor freight sprayer for acoustic ceilings, and leaving it on for 24 hours. Forget about using a plastic scrapper, rent yourself the biggest baddest pressure washer. 4,000 PSI really takes it off! My project has taken at least 2 strips to get everything off. I found that the first layer with either product melts it off. I stood both halves of the cowling on end when I sprayed them. 24 hours later the first layer had fallen off entirely.
Yeah it’s work. As an aircraft mechanic I’d seen commercial airliners stripped and wasn’t in a big hurry to do it myself. Now that I’m almost done, it’s messy, but not that bad with these 2 less toxic strippers.
I will be happier when the painter takes over and starts shooting everything white on white on white. I plan on doing all the color in vinyl. I’m thinking the military star and a couple simple stripes out by the wingtips. I’m still looking for the right design for the vertical stab/rudder. I’ll probably make a completely irreverent logo for a chemtrail Geoengineering dispersal unit.
