Tailcone faring
Question?? Will I need to remove the horizontal Stabilator in order to fit or install the fiberglass tail-cone faring??? I’m a long ways from doing it but would like to know if it’s going to be an issue.
If you know someone with a RV-12 that's done a conditional inspection on their plane, ask them how they get inside the tailcone to inspect, and LPS2 lube the ball bearing joints inside there.
That should answer your question.
I am installing the tailcone on my RV-12 (not the RV-12is) and the tail feathers are off. So it may be model specific.
