Tailcone attach question
unitink72
Looking for a sanity check here.
These are the two bottom corners where the fuse side skins, mid fuse bottom skins, and tailcone meet. To help orient your eyes, the tailcone still has some blue plastic on it.
Do these look right?
The picture on the right is most correct, though I don't think it's a problem if you have the bottom skin between the tailcone's bottom and side skins as in the first picture. It looks like you are still in the fit-up stage but be sure to round the corners of the side skins. Not only do you not want that sharp angle there to catch on things, it'll look nicer. Really, I think Van's should have us take the corner off the tailcone's side skins to accommodate that bottom skin joint, but when I discovered it on mine, I decided not to attempt to fix it as I was likely to do more damage than good.
Mine is situated like your photo on the right. Both fuse skins overlap the tailcone skins entirely. (You have that one on the left photo wedged in between)
