Tip Up Frame Madness
OK fellas, I need help or I need a quick build frame!
The TU frame was set up beautifully, the 0.20 gap was perfect along the skins and the skin sides sat nicely along the fuse line. 1/8th spacers sat under the side rails and the side rails sat perfectly into position. All taped and ready to go. Drilled the hinge holes and the canopy worked like a treat.
Then I put the struts on and WOW, it all went pear shaped, here you can see there is a 3/8th rise on the skin;
Here you can see that the skin no longer sits on the deck, on the right side it has risen by 2/8ths and on the left by 3/8ths. There is so much spring in there, I push my hand down on it and it nearly goes back into position, but when I release my hand it springs back.
So, I have spent night after night trying to work out just why the struts have had such an effect on the frame.
I tried to reshape the frame but there is only so much you can do when the C614 has been riveted. I filed here, I field there, I moved the aft strut support back 2 1/2 inch in the hope it might releive some of the pressure. Nothing worked. Then I took out the hinge bolts, pushed the frame down, reset it all and got a good fit, with the hinge bracket hole now completely out of line with the guide holes.
I have done EVERYTHING on this frame by the book and to the plans, I have spent a lot of time getting it right becuase for me it has to look great, I can't tell you how pissed I am. I have no idea how this could have happend but it has and it's really demorolised me.
1). How do you think this has come about because I haven't a clue how it's happened?
2). Can I weld the hinge holes in any way so that I can still use this frame?
3). Has anyone else experienced this when puttng the struts on ?
Martin
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
