All things are inteconnected, grasshopper
I'm so glad this thread popped up. I'm very early in the build process, but I started to think about my avionics, switchology and stick buttons. These things are all intertwined and need to be considered in relation to each other. I've got a couple of posts on my construction log dealing with these things. These are just the beginning of my thoughts and there is more to come. I use MyKitLog for a construction log and it doesn't give you a lot of space to capture your thoughts. That's not necessarily a bad thing because it forces you to be brief and to the point.
Basically, I wanted to write down the criteria for joystick buttons and the logic for choosing to include or exclude them. Having things in writing forces one to think through the reasons why you should or should not put a function in a particular place. This gives you time to realize that what seems to be a good idea initially really isn't when you think about it for a bit. For the record, I feel that a starter button on the joystick is a really, really bad idea.
Panel design
Joystick switch philosophy
There's a saying at work. "Make functions earn their place on the panel or control." I'm a detail oriented person, so an exercise like this just makes sense.
This same procedure is necessary for switches as well. For example, is it really a good idea to put the avionics master switch right next to the fuel pump switch? (hint: no!) That'll be my next avionics post when I get time.
Once I'm reasonably satisfied with the logic for the entire system, I'll go to Kinko's and get a full scale print of the panel, paste it to some cardboard and go through operational flows to help build checklists and to see if there's any further room for improvement.
I wanted to get an early start on this process so I can lay the initial groundwork and let it marinate in the back on my brain for a while. I'll revisit it from time to time throughout the build and tweak it as required. When it comes time to commit to the avionics I'll have a solid plan in place when I discuss with whoever I choose to build my panel (probably Steinair).
Unnecessary P.S.: My 100th post!
