RVG8tor
I have fit the wings and set incidence and drilled the rear spar hole up to 3/16. The wing is square to the fuselage within 1/8". In double checking things I discovered the leading edge of my wings have a slight sweep forward. With a line drawn between wing tips at the leading edge, when a drop a plumb bob at the root end it sits 1/4" forward of the tip to tip line. It is the same with both wings, they appear swept forward the same amount
So the question, do I call this good or since my rear spar hole is undersized do I try to correct this. Knowing any new hole I drill can have an effect on the incidence. I am looking for opinions, I am thinking I am being too anal about this. I guess I was not anal enough in the first place.
