Hello folks,
I am an aerospace student from Germany. In the moment I am working on my bachelor thesis, which describes the flight testing program, referred to the performance requirements, for a RV-7 to get an amateur built aircraft certification. This also include the creation of the performance chapter of the POH.I am planning to start my test program in 10 days. Because of that I need some information and references from experienced RV-7 builders and flyers.
My RV-7 has:
a Mattituck TMX O-360 engine(180BHP/132KW)
a Prince Aircraft 68/78 (diameter/pitch) fixed pitch propeller (2 blades)
MTOW 1800 lbs
If you have a similar RV-7 I would totally appreciate it if you send me an e-mail with the following information:
1. Important Speeds in kts (calibrated airspeed CAS)
VS0 (stalling speed or the minimum steady flight speed obtained in a landing configuration):
__________ CAS in kts
VS1 (stalling speed or the minimum steady flight speed obtained in a specific configuration):
__________CAS in kts
VX (speed for best angle of climb):
Vy (speed for best rate of climb):
VR (rotation speed):
Vbest Glide Range ( speed for best glide which gives you the best rang; best angle for descent):
Vbest Glide Endurance (speed for best glide which gives you the best endurance; minimum rate of descent):
Please let me know if your speeds are already reduced to Mean Sea Level and MTOW (like in the ?Flight Test Guide For Certification of FAR-23 Aeroplanes Part2 Appendix-1&2&3? prescribed).
2. Additional information
engine-type: _______________________________________________________________
engine manufacturer: _______________________________________________________________
propeller facts: _______________________________________________________________
best rate of climb (ROC): ________in ft/min
balked landing (ROC): ________in ft/min
glide ratio: ________
max. continuous power rating: _______RPM
max. power rating: _______RPM
Special modification which has relevant effects on the aircrafts performance (if applicable):
My E-mail address [email protected]
It is also welcome if you directly send me the performance parts of your POH. Thank you very much for your efforts.
Moreover I have several questions which we can discuss within this thread:
1. I it corrects that a Mattituck TMX O-360 engine is equal to the Lycoming A4M?
2. Where can I get the ?Sea Level and Altitude Performance Chart? for this engine?
3. Does anybody have data referred to the efficiency for my Prince Aircraft 68/78 (diameter/pitch) fixed pitch propeller (2 blades)?
4. Do anybody has the Lilienthalsches polar diagram or any data for the NACA 23013,5 profile?
5. How can I calculate the airspeeds mentioned above theoretically? (Especially Vy ,VX,Vbest Glide Range ,Vbest Glide Endurance )
Thank you all for you efforts.
Best Regards,
Mr. Hunger
My RV-7 has:
MTOW 1800 lbs
Best Regards,
Mr. Hunger
