JanRV6UK
Just looking for a bit of info on stick lengths on the RV6. When the grip is fitted ? and to ensure that the stick can be moved fully in the square cut out (as I have control surfaces connected I assume that the stick should move fully in the floor pan cut out ??)
Simply put - do you end up with 14 ? inch from the top of the trim switch on the stick grip to the floor pan .. or do you trim it down a bit to ensure you do not hit the instrument panel or the throttle cluster ? To short a stick is not so good .. I understand .. but how short is to short ??
![fjomf7.jpg](/proxy.php?image=http%3A%2F%2Fi61.tinypic.com%2Ffjomf7.jpg&hash=6afce6f2e1ae313451612f320387d2cc)
