In looking through archives I've reduced the 2 Stewart Warner oil coolers commonly used in Rockets to be either a 8432R or 10611R ?? I emailed Stewart Warner to ask what the differences between the two are and their respective cooling capacities. Their response was discouraging - "I cannot give that (information) out". What ???? Are you saying I can't get technical information on a technical product ???? But they did give me a link to a Stewart Warner distributor that makes some good information available:
http://www.oilcoolers.com/products.htm
http://www.oilcoolers.com/LCHX Specifications.pdf
What I gleen from this is that the 8432R and 10611R have essentially identical cooling capacities but different air-flow characteristics and different inlet/outlet configurations. Can I get some more experienced help here ?? Bottom line is that I am after the oil cooler with the greater cooling capacity and cleanest installation in a Rocket.
Thanks !!!
Thanks !!!
