Like many RVs mine is unique in many ways, but the static port was not one of the items that was ever noticed. It's just a hole.
My RV always seemed slow compared to others published numbers and Van's. This always bothered me...did I buy a dud? Ultimately I was happy with real performance, ie the gas milage being better than my car and my commute taking 1/3 the time. However, I searched for every bit of aerodynamic issue with the aircraft - wing, flight control, and gear fairing rigging, all to no avail. The pilot static and altimeter test also good.
Then I see a thread in the -9 forum about someone in like circumstance. The community to the rescue! Everything pointed to the static port! I remembered it was pointed out in my pre-buy that I didn't have the Van's pop-rivet port, so I took a 4-leg WOT test drive at 8500', captured G3X screen shots of my metrics and then plugged my data in the NTPS spreadsheet provide here. Well...I was indicating ~10 too slow...what was 148 KTAS was actually 158! Within 2 knots of the published Vans numbers!
So...how do I fix? Well, I'm not smart, but I can copy! I just modified the flush port to install a unset large flange 1/8 rivet like the one Van's provides. Retested, and my IAS and indicted TAS are now within 1 knot. Happy Days!
However...my IAS, and to a larger extent, my ALT and VS is jumping around a tiny bit. Very small deviations, but not very agreeable with my autopilot. Any idea what would cause this?
