Stall warning wiring
Does anyone know how to pin the stall warning on the D180 12 control board to the Garmin Gtr 200 radio? It appears to pin to the Gtr as an auxiliary input At pin 32. But where is the output from the board?
Do you mean the AOA (angle of attack) data? The audio warning tones are output from connector DB25, pin 18.
Yes AOA. In the D180 wiring diagram I have the 25 pin EFIS pin 18 going to the board 30 pin Efis. But, since I’m using the Garmin 200 I should connect pin 18 to the Garmin 32 pin?
