New in stock...stainless steel tubular firewall penetrations in three diameters, all $19 plus shipping. That's right, no price increase. And shipping is free with a firewall insulation kit.
For the RV-8 builders, a new triple penetration matching the 1.5" spacing on the firewall plan...throttle, mixture, prop.
I have some remaining mild steel double and triple penetrations, so it's time to clear 'em out. The double can be used anywhere. The triple matches the RV-10 firewall drawing. They're delivered bead blasted and ready to paint. Note I've been flying mild steel penetrations on my own airplane for 15 years, painted with rattle can Rustoleum, and they still look great. Mild steel and stainless steel fittings perform the same.
Tubular steel penetration fittings are absolutely fireproof and gas-tight.
Installation is dead simple; cut an appropriate opening, deburr, and attach the fitting with some sealant under the flange using any steel pop rivet. The flange may be installed over or under a firewall insulation overlay.
From there, two choices. For control cables and large electrical cables, just pump the annular space full of FireBarrier 2000+ or other silicone base intumescent sealant.
For a bundle of small wires, apply a skim of sealant around the annular space, then use two clamps to fasten a short length of standard firesleeve. This approach allows adding or changing a wire later.
No website. This is a hobby. Download the attached order form/info sheet (.zip file), or PM, or email, or just click here.
