Since my QB Wings & Fuse won't be here for at least another month, I've decided to finish the tail fiberglass.
My plan is to fill the edge/gap between the fiberglass tips and the aluminum skin with dry micro after roughing up both the skin and tips, lay a light piece of fiberglass tape over the gap (pre-wetted using the plastic sandwich method) and then microslurry over the top of that + sanding to fair. Since I have plenty of time and I like the way that finish looks, that's the plan.
I've run into a couple items that I want to address before heading down this path. My apologies for the poor photos.
Issue #1 - Difference in surface height between elevator tip and elevator skin leading edge. My plan to address this is to sand the gelcoat off, apply dry micro to level the gap, sand to shape. Anyone see any issue with that? Any advice?
Issue #2 - This one's the more concerning of the two. There's a significant difference in the width of the hs tip vs the elevator tip. I'm a bit more perplexed as to how to fix this one. One option would be to stuff an oversized piece of foam shaped to match the elevator into the hs tip. Maybe add a bit of heat to soften the piece. Another option would be to add a bunch of micro on the elevator tip and match the outline. That would be a lot of micro... Has anyone else seen this? Any recommendations? (I know... horrible picture.)
Since I'll be sanding some of the gelcoat off, should I just sand it all off?
Thanks!!
Thanks!!
