CaptPausert
In the instructions for the wing assembly, it says to prime the countersunk holes on the wing spar where the anodizing is removed but this instruction is after you attach the plate nuts as you need to rivet on the plate nuts as a guide. Are we supposed to prime the countersunk holes where the rivets go or just the ones for the screws? I was going to call Vans builder support and ask but got busy with work.
