WingnutWick
Has anyone done it? Characteristics? Recovery?
Thanks!
Thanks!
Probably not applicable to the eight but I have found the F1 Rocket will recover itself as soon as you neutralize the controls after spin entry. I can?t even get to the point of applying opposite rudder. This is solo with the CG near the forward limit. I am interested if anyone has spun the F1 with the CG closer to the aft limit.
G
50 turns in an RV, or the Cub?! Tell us more, please...It spins like a good airplane should! Very typical spin behavior with no bad characteristics I was able to trigger ( and I tried .... ). Any of the couple of typical recovery techniques works for me. Neutral stick, forward stick, opposite rudder, neutral rudder take you hands of the controls. Some take longer to recover then others but with some patience they all get me out of it.
If you do lots of spins (50 turn is my max so far) the engine will eventually quit ( after 10 turns or so ) and the prop will stop unless you have inverted fuel due to centrifugal force on the fuel. No big deal will start right back up after recovery.
Be safe and have fun!
Oliver
RV
Here a 47 turn one I got on video I shared before:
http://www.spatscheck.com/oliver/Spin.mp4
I kind of got lazy taking videos so I don't have anything current with the 50 but it's basically the same just a few hundred feet more altitude.
Started at 14500 spin was done by 6000 feet needed another 1900 ft to stop rotation and get fast enough to get prop spinning again and pull out (don't like using the starter while flying otherwise you can pull out much quicker). After the engine quits and prop stops everything goes quite. It's very peaceful. Spin flattens out a little bit.
Oliver
Oliver, that is very impressive - thanks for sharing it. Just curious, even with a flop tube, unless the tank were totally full, wouldn't the fuel pickup run dry?...If you do lots of spins (50 turn is my max so far) the engine will eventually quit ( after 10 turns or so ) and the prop will stop unless you have inverted fuel due to centrifugal force on the fuel. ...
Great video! Curious as to why you don't use the starter for the restart? Is it possible to overspeed the starter?
Best,
Jim
Ah yes, totally forgot about that! Thanks.You are right the flop tube alone would work only with lots of fuel but the inverted fuel kit from Vans also puts a trap door in the tank which will keep some fuel in the area of the flop tube. I am told that works.
