EchoJuliet
Member
In the RV-12iS POH, section 8.6, an electrode gap of .8-.9mm/.031-.035 is listed for a NGK DCPR8E plug used on a 912iS. This is incorrect. That gap would only be used for the newer Rotax 297656 spark plug. If using the NGK DCPR8E on the 912iS you would gap to .6-.7mm/.023-.027.
Vans has been notified and confirms that it is an error, but I'm not sure when/if they will make the correction.
