Some Titan IO370 performance numbers
Freemasm
This was kicked-off by the Aerosport recent IO375 thread, Didn't want to contribute to the drift -> hijack.
These are for reference only. This:
is not a statement about vendor supremacy
is not a statement about appurtenance choice preeminence
is not a large enough sample to offer any conclusions
has several unknowns like spark advance
etc.
I believe Titan nameplates all IO370s at 195HP regardless of configuration. The baseline would be O360, 8.5:1s, Mech FI, Mags, "hot" sump, etc.
For reference only. See attached.
  • Perform Compare.pdf
  • IO370torque.power curve.pdf
  • Torque Chart.pdf
Running Strong
Interesting!
Mine is one of the engines on your data sheet. The "Jeff Romuald" build at 206.5 HP, EFII.
I have it installed on my RV-7 and paired with a Whirlwind HRT prop. performance is awesome!
I have about 350 hours on the engine and it has been running flawlessly for about 4 years.
Forgot to add that when I bought the engine, they were just bought by Continental. They were still located in San Antonio at the time. I dealt with JB for the purchase and the transaction was stellar. I traveled to San Antonio and watched the build with Bobby Looper. After they dyno'd my engine (very pleased!) I drove it home to Wisconsin. To boot, no sales tax since Wisconsin does not charge a sales tax on aircraft parts!
Jeff, I was just in your area this summer, bought a tool post grinder and stopped there to pick it up on the Mi side. Wish I knew you were there.
What is your 8000ft DA max cruise KTAS and RPM with that 370? I have CS prop and say RPM because 2550-2650 was my max speed with the Hartzell composite. I keep tweaking the mixture until the airspeed stabilizes at max speed. It seems to drop 2kts from peak to full thermal balance - about 15-20 min. Not sure exactly why??
I have the stock M1B with standard timing mags.
