RV-14 page 09-24 step 4. Trim servo leads.
Rather than use the molex connector for the WH-00073 extension I decided to eliminate the molex and just use solder and heat shrink. I soldered the wires together with out much problem and shrunk the individual 1/16” tubes around each connection, was happy with the result. Then I realized I forgot to put a section of larger tubing to go around the whole bundle to make it look tidy and give it some strain relief.
What would you do? Unsolder and start over? Not solder in the first place?
I wrapped electrical tape around it. I think it’ll do the job but it looks unprofessional.
