bkc3921
FYI..12is, Section 39, Canopy, Page U13, Dated 02/04/19, Revision 2, Attaching the canopy guides to the roll bar:
Step 1 in the KAI says to "Final drill to #19 the holes..." and then "tap to 8/32"..(to receive a #8 screw)....Van's confirms the #19 hole size is an error, and will be corrected when engineering gets to it.
A #19 hole is far too big for an 8/32 tap. If you drill them, you will have to tap for a #10 screw, slightly enlarge the holes in the guide block, and come up with 4 #10 screws on your own. Probably should have said "Final drill to #30 (or so)"
Don't ask me how I know this.
Sorry if this has already been addressed on this forum, but I could not find anywhere it is mentioned. Proceed as you see best.
