Afternoon all,
So I have done some searching and plenty of reading re canopy and frame set up. From all that I have been able to gather, the front height of the slider frame is always set after the plexi is installed. Can someone provide as succinct answer as to why? The plans clearly show a 3/8" height difference between the canopy frame and the roll bar, and if I put a straight edge across the two like the plexi would want to sit in an ideal world, the 3/8" dimension is perfect. So if that's the case, why not trim each leg now to set the desired height?
To the contrary, you are supposed to lay out and drill the aft track but I am going to wait to do that until the canopy is glued to the frame so I can set the height of the aft end more precisely to account for the extra height of the adhesive instead of the rivets. Any issues with that plan?
