woodsideraff
I have an intermittent open circuit in the Right EGT connection. In the process of trouble-shooting the problem, I discovered that the Right and Left EGT wiring in the harness are reversed.
I'm wondering if I have a rouge harness or do others have the same wrong wiring. If you don't have problems, the only way to find out is by disconnecting one probe and associating it with the display.
Of course, it can be easily solved, as I did, with software assignment.
Regards,
Rafael
Regards,
Rafael
