SeanB
Just starting to install Skybolts along the firewall. The aft trim line of the pink fiberglass is trimmed for the upper. I used the cleco inserts in the Skybolt tabs, back-lighted them, and drilled some 1/8" holes. I'm somewhat confused on the next steps...... Do I back-light those areas again (minus some of the cleco inserts) and trace the larger circle from the tabs onto the fiberglass? Then do my best to step drill inside that drawn circle? It seems the lighting can diffuse a bit while doing this and I fear not getting the best location for the full-sized holes.
Tips or comments greatly appreciated. Pics even better!
Thanks.
Thanks.
