Skybeacon
John, my unit is a self installed FreeFlight UAT, but here are two issues I had that might affect other units:
1. I transposed two characters in the ICAO hexadecimal code for my plane and got a call from FAA asking to get it fixed.
2. My D180 encoder was set to a default output resolution of 100 feet which was causing a BARODELT fail. The ADS-B required an altitude resolution of 10 feet.
Hope this helps.
Rich
I've heard of some Skybeacon issues in an Aviation Consumer article recently, I installed the Garmin GDL-82 in my RV12, although the install takes longer it worked perfectly and I did get the $500 rebate from the FAA after a successful flight test with no issues. However the article does state that your location, if "far away from good radar and ADS-B coverage" there's a good chance of failing the flt. test...this was in the recent June 2019 edition.
