Sikaflex questions. Hopefully those of you that have done this before can help with a few questions. I may have already made a mistake as I've already cut my door window lip down to 3/4" per the plans. I believe I understand the general process but have a few specific questions.
I've watched the Glastar/Sportsman window video and read the thread below.
Questions,
Thanks for the advice!
RV-10 Window install adhesive...continued
Merry Christmas fellow -10 builders! I'm finally to the point where I'm about to install my windows and am considering the adhesive options. This topic has been discussed many times, so I'm not looking for "the best method". I took some time off from building (life got in the way...), but...
www.vansairforce.net
Questions,
- How much gap do I need between the window and cabin top? I'd like to have it as small as possible. I’ve read some are using ¼”, is this much necessary? I’d like to have 1/8”, this will also leave more room for bonding the window to the door.
- How much bonding area do I need between the window and door lip? I've read that 1/2" is sufficient.
- Use clecos and washers or spacers to hold the window up and flat with the cabin top? Or, just let the sikaflex settle, pushing out the excess with clecos/bridges only pushing the window down flush.
- How much do the windows actually expand and contract? I understand the finished fillet of Sikaflex actually bulges in the heat.
