David Paule
Congratulations!
Nice looking prop - and the brakes work, too.
Thanks for sharing it, Andy!
Dave
Dave
Yes - all interior primed with Zinc Chromate Etch. I have a list of where I think the savings were made, using a few (2 in particular) well documented RV-3 builds on here. There is no single item that "saves a lot", it is just thinking weight at every point / decision. The panel above shows the idea - the easiest way to save weight is not to put something in at all.Most RV-3's are around 800 lbs, where did you save the most? Did you use primer?
I'll take bets on how much the blue film weighs (the canopy plastic and masking tape was >8oz).
The answer is just over 3lbs So now below 730lbs and could shed another 1lb 4oz by changing Bell Fork + std Vans TW for Vans Fork + Vans Lightweight TW - but that is more CG control to meI'll take bets on how much the blue film weighs (the canopy plastic and masking tape was >8oz).
You could use the Harmon Rocket parts.
Should work.
I`ll build one if I ever get the time.
cheers
Tail's on! Temporarily, of course. Still a lot of work to do with control surface rigging, trim tab cable routing (grrr), and fiberglass.
