Shout Out to A.C. Propeller in Seattle and Southwest Aero in Tukwila
ArlingtonRV
Patron
Just wanted to give a shout out to A. C. Propeller in Seattle. After 25 years and about 2,500 hours, I figured it was time for an overhaul. I have a Hartzell HC-C2YK-1BF with the F7666A-2 blades. I've never had any problems with it and the blades were in extremely good shape, but last year when I pulled one of the plugs to service the hub, grease started oozing out before I did anything. That made me think that the hub was full and that maybe it was time.
I dropped it off on 3/20/26 and was told that it would be done in 6-8 weeks. I picked it up on 5/22/26 which was exactly 8 weeks from when I dropped it off. I was very glad to hear that there was absolutely no corrosion anywhere inside the hub and everything looked good. At the time I dropped it off, no sooner was the cart in the shop when one of the guys came over and said they no longer work on Woodward governors. That was a problem, since I have a Woodward governor. I panicked for a few minutes, but they quickly followed up that the guy that used to do their governors opened up a shop in Tukwila and they would send it to him. That is Southwest Aero. The governor was ready for pick up at the same time as I got the prop.
I didn't mind the down time as I was doing my condition inspection at that time and I also wanted to do some other things, most notably changing the engine mounts and replacing the O-Rings on all of the intake tubes.
If you need a cure for insomnia, I have a series of blog posts that detail what I did. The first one is here and there is a link to the next post at the bottom of each post, until, of course, you reach the last post. It may not seem like it, but you will eventually get to the end. The post that shows putting the prop and governor back in / on is here. The video of the test flight is here, but there are no real testy details in it.
