I knew it was too good to last. Did AntiSplat bearing mod on nose and mains. I was enjoying smooth taxi and no fuss roll outs for 2 years. Changed nose wheel to retread with what looked like double tread depth. Now, just before making the turn after landing @25-30 and before braking, I get a shimmy that lasts for 5-10 secs, then I brake, still a bit of shimmy, then it goes away and I taxi back. I recently sent the nose back to Alan for dynamic balancing and a skim of the OD. I have the same shimmy at 25-30.
Played with tire pressure, checked break out (little high @34 Lbs). Not worth drilling extra holes to get the spec). A little higher works, since it always decreases over time. Checked landing gear SBs (no cracks).
Any hidden diagnosis from the collective? Natural frequency at that speed?
Current:
Nose 35 PSI
Mains 50 PSI (68 PSI max GY III)
Current:
Nose 35 PSI
