Apologies in advance if this is not the correct section.
Looking to interface a GNS-430W with a MD200-306 CDI. Based on the Garmin installation manual, shield grounds should be terminated at both the GNS and the CDI (first picture below). I understand that shield grounds are terminated on the GNS end via the connector backshell. However, there is no provision for terminating the shield grounds on the CDI connector backshell (second picture).
Do the cable shields need to be grounded at the CDI end? If so, how?
The Garmin manual (in note 2) seems to indicate connecting shield grounds to "aircraft chassis." Do people actually do this? Harnesses I've seen don't have any provision for shield grounding at the CDI.
