Michael Burbidge
How did you set the two rivets that attach the lug assembly to F-01406C? Given the angle of the lug assembly I assume the only way to set these is to put the manufacture head on the rear, and use a rivet gun from behind and an angle bucking bar from the front.
To do that I really need to get inside the fuselage, but it is only clecoed together at this point. Is it strong enough to support the weight of a person?
Michael-
Michael-
