Servo tester
Would like a recommendation on what simple servo tester to buy. Thank you.
In case you are talking about PWM controlled servos like the ones being used in the RC world:
I really like this one:
https://www.servocity.com/servo-commander/
It supports 4 different servo input signal ranges.
If you want to run it from 12V, use this:
https://www.servocity.com/6a-bec-vo...-input-5v-6v-8-4v-12v-output-xt30-connectors/
You probably want the connectors, too:
https://www.servocity.com/search-results-page?q=3803-0102-0005
/M
