RV10
date 4/11/07 securing flap actuator rod end- is this under the floorboards?
16-03-28 cracking of aft spar web at inboard hinge bracket- is this best inspected through the cover near the tie downs?
36 rev 3 cracking in HS rear spar at outboard hinge brackets- seems easy enough to look at half of this without help but best would be using a borescope aimed back 180 degrees? Is that what folks do?
19-09-09 Cracking of nose gear leg inboard attach lug- How do I tell visually upon inspection if this part has been changed out? On the SB the actual parts look similar.
90 dynon SB re SV-AP-Panel- Is it safe to assume that my 2022 Dynon install was not from the affected serial numbers? If not, how do I find the number?
Thanks.
Thanks.
