has anyone used self leveling or spherical washers on bolt applications that are not perpendicular on your RV? If so, do you have a good source for these? google brings up several options but I would like to know fellow builders experiences here with use and reliable sources.
My particular issue is a HS RR spar -3 bolt that is about 4 degrees off. I'm guessing that I could sand a washer to angle on one side for the bolt head and nut side but how do you get it the same angle?
if I use a spherical washer set, it will add .5 inches to the overall bolt length to maintain the grip range throught the washers and structure. The -7 bolt grows to a -12 for grip and minimal threads sticking out of the nut after torquing. Is this acceptable?
