jsharkey
Flap Hinge Pin Securing
I drilled a 3/16" hole in the outboard aileron brackets so that I could insert and remove the flap hinge pins as necessary.
I had intended to simply form a 90 deg bend on the outboard end of the pin and secure it by wiring to the aileron bracket. However having just set up the aileron stops I find that the flap hinge pin interferes with the aileron horn at close to full up aileron deflection.
You can push the aileron to the hard stop but the flap pin is definitely interfering.
How did anyone else deal with this and/or secure the flap pin differently?
Has anyone tried filing a notch in the flange of the aileron horn to clear the pin?
I like the bent over end of the pin as it give something to lever and grip to get the pin moving when removing it.
Jim Sharkey
RV-6 - Getting there!
Jim Sharkey
