I’ve got .42 degrees toe in on the left axle and .22 degrees toe out on the right axle using the Vans method. I was thinking of putting a .25 degree shim in the left axle which would bring it to .17 degrees toe in. On the right axle I was gonna put a .25 degree shim in which would put the right side at .03 degrees toe in. Vans says toe in is preferred.
Does this sound like a reasonable approach? Thanks
Todd
Todd
